"Revision Description Required" for Revision 1.1
"Revision Description Required" for Revision 1.1 (migrated thread) Posted: Apr 16, 2012 3:12 AM
becker Posts: 13 Registered: Nov, 2010
I'd like to have "revision description required" for Rev 1.1 instead of "initial version" automatically inserted in the revision description of 1.1. Is this possible?
Re: "Revision Description Required" for Revision 1.1 Posted: Apr 24, 2012 12:38 PM
Posted By: mlizak Posts: 72 / Registered: Feb, 2011
Hello Becker,
Unfortunately, this is definitely not possible. The default text for the initial revision description is compiled into the code.
Kael
    KaelLizak16-PearlAuthor
    If this issue is of concern to you, please contact Integrity Support, so that you can be added to the appropriate SPR.
