Mar 3, 2020 2:30 PM UTC
Setting requirements categories based on object type
Is there any way in Requirements Connector to set the requirement Category type based on the Object type?  Instead of a one to one relationship between requirement type to document container, DOORS NG uses multiple object types within a container.  So a Header would be a Heading Object type, a Comment would be a Information Object type, etc. PTC Integrity achieves this with a Category field.
But once I refactor a multiple object type ReqIF file to something Integrity can read, I don't see a way to set the Category to reflect the above different Object types.
Anyone know of a way?
Mar 4, 2020 3:18 PM UTC
Hi pnewhook,
I don't believe this is possible, as IRC currently only supports the one object type, hence, why you need to refactor to begin with during import:
https://www.ptc.com/en/support/article/CS280996
You may want to open a Support case with the Integrity Requirements Connector support team, to confirm, and see if this has changed, as I haven't used IRC in awhile.
pnewhook10-MarbleAuthor
Mar 5, 2020 2:32 PM UTC
IRC has supported multiple object types since 3.1 (confirmed in the link you provided).  I'm now using 3.4
