Shared Test Case field configuration
In our current build (Integrity 10.7), a Test Suite item can be edited in the Integrity Client's Document View to create a new Test Case item. This Test Case item automatically has a Shared Test Case item created and related to it via the "References" field on the Test Case item. Field values  provided through the Document View (such as Category, Reference Mode, Text, etc.)  then appear on both the Test Case item and the related Shared Test Case item.
Is it possible through configuration to add to the list of fields that are populated on both the Test Case and Shared Test Case at creation? We are currently unable to identify where in the configuration this is determined.
Our goal is to add to the list so that additional fields can be stored on both the Test Case and Shared Test Case items at creation.
Bryan
brague1-VisitorAuthorAnswer
