May 4, 2018 5:59 AM UTC
Showing Dates/Times in higher resolution
Hi all,
is it possible to see the contents of fields such as "created date" or "modified date" in a higher resolution via the command line or API? For example, up to milliseconds? If i enter the following command:
im issues --fields="Modified Date" 123
i got as an example following answer:
May 3, 2018 4:11:27 PM
I know that an admin can change the display settings for date and time fields, but there doesn't seem to be a setting for a display including milliseconds. Am i wrong (hopefully)?
Thanks, Jens
