si co without a sandbox created before is possible?
From my knowledge it is possible via the commands to check out/check in:
si createsandbox
si co (check out) and
si ci (check in)
the question I have is if it's possible to do this even without creating the sandbox before. So like it is done on web interface where you can work directly inside the project without a sandbox
11-Garnet
Hi @MW_8240570 ,
Right now its not possible to perform CO or CI without sandbox. This is applicable for web interface as well. This is one of the needed feature require in Integrity as other competitive GIT based tools provide this.
Sathish
In former Integrity revisions there was 'si projectco' for this.
As far I remember this command needs a so called PROJECT_CONFIG_PATH
to point to a project on the server.
Was this really removed meanwhile?
You mean "si projectco" itself?
That command is still available in the product as of 12.4.
https://support.ptc.com/help/windchillrvs/r12.4.0.0/en/#page/IntegrityHelp%2Fsi_projectco.html
Mike C.
