[SI] readonly DevPaths?
Hi @all,
is it possible to set a complete Branch (DevPath) in source to readonly, and the parent is still writable?
Thanks, Jens
    mrumpAnswer
    Hi Jens,
    that's easy.
    You just need to create a specific ACL for the Dev Path and deny the
    • checkin,
    • modify member revision
    • add member,
    • drop member,
    • add subproject,
    • drop subproject,
    • and configure subproject
    permissions for the everyone groups
    HTH Matthias
    Note: Keep in mind that you ensure the ACL for the Dev Path is not inherited from the mainline.
    mrump16-PearlAnswer
    Hi Jens,
    that's easy.
    • checkin,
    • add member,
    • drop member,
    • add subproject,
    • drop subproject,
    HTH Matthias
    JensN.1-VisitorAuthor
    Hi Matthias,
    thanks again
    kind regards, Jens
