May 23, 2019 9:53 PM UTC
si viewproject with sub-project pathes
when calling si viewproject -R, all members and sub-projects are shown with indentation. Now I'm using --fields=memberarchive to get the entire path of the member instead of indetation, but this does not work for sub-projects. Is it possible to recursively Show all sub-projects with full path names and the Information whether and how it's shared?
Kind regards,
CHristian
May 24, 2019 6:06 PM UTC
I haven't found a way to do this yet with viewproject. It would be a very helpful idea.
The closest you can come is using a sandbox - viewsandbox does give the full path to the subproject files.  You could then replace the sandbox path with the project path to get the correct subproject path.
Any shared subproject will show as with "shared" , but the subproject of the shared subproject don't have this indicator (unless they are also shared)
However, if the subproject is moved, then there's no way to see this, unless you look at the member archive locations.
You can get a list of just subprojects by adding a filter that will not return any members, for example "--filter=file:onlysubs"
For example:
Viewproject output:
D:/private/sandboxes/12/almsoln>si viewproject --recurse --nofilterSubs --filter=file:onlysubs
 new/project.pj shared-subproject
 sub_feb/project.pj shared-subproject
 test/project.pj subproject
 watch/project.pj subproject
 blue/project.pj subproject
 red/project.pj subproject
 lilac/project.pj subproject
 purple/project.pj subproject
Viewsandbox output:
D:/private/sandboxes/12/almsoln>si viewsandbox --recurse --nofilterSubs --filter=file:onlysubs
 d:\private\sandboxes\12\almsoln\new\project.pj shared-subsandbox
 d:\private\sandboxes\12\almsoln\new\sub_feb\project.pj shared-subsandbox
 d:\private\sandboxes\12\almsoln\new\test\project.pj subsandbox
 d:\private\sandboxes\12\almsoln\watch\project.pj subsandbox
 d:\private\sandboxes\12\almsoln\watch\blue\project.pj subsandbox
 d:\private\sandboxes\12\almsoln\watch\blue\red\project.pj subsandbox
 d:\private\sandboxes\12\almsoln\watch\blue\red\lilac\project.pj subsandbox
 d:\private\sandboxes\12\almsoln\watch\blue\red\purple\project.pj subsandbox
ChrisIng1-VisitorAuthor
May 24, 2019 9:10 PM UTC
Hi, yes, viewproject helps in my case. Thanks. Regards, Christian
