Source Integrity APIs
What is the list of API integrations that are available for MKS Source Integrity.
For instance I know there is a MKS integration for working in IBM Rational Developer and there used to be a MKS integration for Visual Basic 6. Is there a MKS integration available for more recent versions of Microsoft Visual Studio ? Thank you.
    Hi Mary,
    Here are the official lists of Integrity integrations (depending on your Integrity version):
    http://www.ptc.com/WCMS/files/142568/en/Integrity_10_x_Integrations.pdf
    http://www.ptc.com/WCMS/files/142569/en/Integrity_2009_Integrations.pdf
    The documents mention that some versions of Visual Studio 2005, 2008, and 2010 are supported
    Hope that helps,
    Matt
    Hi Mary,
    Hope that helps,
    Matt
    Hi Mary,
    we've used the VS integration for 2005/2008 and 2010 for some years now.
    There are some things not in the manual you might to consider, depending on the type of projects you develop.
    There is is a basic SCC integration as well, that can also be used with Studio.
    HTH Matthias
