Jan 10, 2013 3:56 PM UTC
Spell Checker
Is it possible to edit the list of words in the spell checker? I only
see a way to add words.
    jgorslineAnswer
    Mar 28, 2013 6:09 PM UTC
    As a follow up: How to change the spell check dictionary in Integrity:
    In the Administration Client, open the Workflows and Documents node, then Configuration and Properties.
    In the list on the right, look for mksis.in.SpellingDictionary. Edit this property and add the path to the dictionary file
    To ensure all users can use the external dictionary, you can copy the dictionary file to the Integrity Server file system, in the <server_install>\data\public_html directory. Any files in this directory can be accessed using the Integrity Server URL.
    For example, the file "<server_install>\data\public_html\En_US.dictionary" can be accessed using the URL "http://<host_name>:<port>/En_US.dictionary"
    The dictionary must be a text format file.
    Jan 16, 2013 9:35 AM UTC
    as far as i know you can use different dictionaries, as example the open-office dictionary. These dictionaries has to be set up at the server. If you have access to your integrity-server (as an admin), you can edit these dictionaries. As a "simple user" it is not possible to edit this dictionary i think...
    kind regards, Jens
    fvanpala1-VisitorAuthor
    Jan 16, 2013 4:04 PM UTC
    Hi Jens
    I unfortunately do not have admin rights on our system, so I can’t use a different dictionary.
    Fred
    Jan 16, 2013 8:59 PM UTC
    Sorry Fred, Jens is right. The dictionary used is a server varable and can only be changed by an admin. Perhaps you can put a request in with your admin about changing the dictionary you want to use?
    jgorsline1-VisitorAnswer
    Apr 8, 2013 12:24 AM UTC
    Hi Jeremy,
    Is the added (external?) dictionary used in addition to the standard dictionary? If so, is the internal library accessible so we can do an automated check of it before adding words to the new dictionary? My IT guy followed these directions to swap in the OpenOffice dictionary but words that aren't in it are showing up as spelled properly. I've parsed a couple of internal glossaries and want to add the new words to the OpenOffice dictionary (and probably delete the standard words from the OpenOffice dictionary).
    Eric
