Test Objective doesn't display category
I would like to have the Category field displayed for ALM_Test Obective items. It is already on the presentation but for some reason doesn't show when you create or edit a test objective. Also, it's not available when I search for it under visible fields. Could someone fill me in on what I'm missing?
fva's as such are very generic and you can use them for sure for a lot of use cases.
But the Category fva should rather be used for documents and nodes only.
Also, when I go to Visible Fields, Category isn't available as an option.
Hello Nolin,
the category field in Integrity is of type fva (=field value attribute), and is intended to mirror the shared category.
Both fields are important for the document model of Integrity.
As I understand, you like to reuse them for a non-document type.
From my experience I'd say that you choose rather another field, and leave the category dedicated to documents only.
The 'other field' can for sure be a pick list, which you might create as a new field.
Does this answer and help?
Volker
Volker,
I think that does. So you're saying fva's are intended to only be used with segments and nodes?
Nolin
