Jun 27, 2018 6:33 PM UTC
Test with Bugs - API
The following c# code snippet gets all tests associated with a bug, but it is super slow and cannot be run in parallel. Is there a way in the WebApi to do the same thing?
private string RunCommand(string bugId)
  var proc1 = new ProcessStartInfo();
  proc1.UseShellExecute = false;
  proc1.RedirectStandardOutput = true;
  proc1.CreateNoWindow = true;
  proc1.WorkingDirectory = @"C:\Windows\System32";
  proc1.FileName = @"C:\Windows\System32\cmd.exe";
  proc1.Verb = "runas";
  proc1.Arguments = string.Format( "/c " + "im viewissue --showtestresults {0}", bugId);
  string result = string.Empty;
  using (Process process = Process.Start(proc1))
    using (StreamReader reader = process.StandardOutput)
        result = reader.ReadToEnd();
 return result;
Jun 28, 2018 1:57 PM UTC
I had a look on our ILM 11.2 server and found http://server:7001/webservices/10/Test/?wsdl. There is an operation called getResults. Please have a look at the documentation here. It seems that an input parameter RelatedToItem may be specified. I think this is what you are looking for.
Best regards, Richard.
References: CS206651 CS206731 CS206732 CS206297
