Trigger code to get issue revision (major or minor)?
Hello team!
Could somebody share a code to get issue revision (major or minor)?
delta.getFieldValue("Revision") or delta.getFieldValue.("Major Version ID") returns null if use inside a trigger code.
But.... if use computed field this pattern works ok .... "toText(getFieldValue(ID, "Major Version ID"))"
What SSE grurs could suggest?
Many thanks!
