unable to change constraints?
I created a table with primary key constraint then I added 2 foreign key constraints, but we changed our naming convention and I wanted to update one of the constraint names but when I promote the script it tells me it failed because constraint 1 was already created.
When I add or change constraints do I need to update the source with Drop commands? or comment out previous commands? what is supposed to be the technique for managing the source for constraints on a table?
    I am going to log a case for this, as you are reporting a specific problem.
    Please log a case from our website, or call Technical Support in the future. The Community is only used for general types of questions .
