Upgrading PTC Implementer
I have only been with this company for 1 year as of yesterday and the job of upgrading the MKS system has landed in my lap.
I'm concerned because I have absolutely no knowledge of MKS/PTC at all and was given the Upgrade instruction manual yesterday.
I started reading it and it is talking about security and rights and things that need to be installed before running this PTC Implementer.
I'm thinking that the Upgrade should not require all that detailed installation and that it should be easier to do than a full blown installation os MKS/PTC?
My question is, is there an easier installation guide for just upgrading the system than the full install/upgrade installation?
Can someone tell me how easy it is to upgrade the system because I'm starting to get a bit freaked out (especially with some of the warning in the install/upgrade manual)?
Thanks in advance for any and all help you people can give me...
Thomas Cusick
Program Analyst
Shop Vac Corporation
(570) 329-4100 (office) | (570) 321-7266 (fax)
E-MAIL: TCusick@shopvac.com
http://www.shopvac.com
    tcusickAnswer
    Thanks for all the help and suggestions.. I was able to setup our account and talked with John on the customer support line and got PTC Implementer 12.0 installed.
    Hi!
    I've asked a Technical Support Engineer to get in touch with you.
    Thanks!
    Dawn
    tcusick1-VisitorAuthor
    I believe they tried to contact me but we have been having problems with the phones and our email systems here the past few days... could you please have them try again as I believe everything has been worked out of the system.
    Ok so right now I put the cd's in our test and prod boxes and I am getting the N/A status and according to the directions I need to install a patch.  When I go to the Patch page it is now asking me for my PTC CUstomer Login?  How do I find out what this is because apparently no one around here knows what our customer login or id is??
    Use your email address and the pass you used to sign on here.
    After I Login and tried to go to the support screen to get the update I get the following..
    Access Denied - Insufficient Privileges
    You are currently setup with a Basic PTC.com Account that does not provide access to this area of eSupport. This means that you may have an active PTC Global Support agreement however you have not yet Upgraded your Account to reflect your Support entitlements. To access this area please Upgrade Your Account.
    tcusick1-VisitorAuthorAnswer
