Using a dash "-" in cli script
Is there a way to use a dash "-" in a CLI script?
When I try to create a field using
im createfield --name=Test --type=shorttext --description="Test - blah blah"
returns an error "MKS124818: No option name or letter was found in "-".
The error goes away when I enter:
im createfield --name=Test --type=shorttext --description="Test blah blah"
Is there a way to embed the character or something?
    I quickly tested the command and it did operate as designed (as you verified as well).
    When you copy and paste the exact command from the script into another editor or regular file, is it copying all of the text appropriately? By chance are there smart quotes found in the original script? What language is the script written in?
    DanR.1-VisitorAuthor
    I typed the command into the command line. Original script? I'm simply trying to create a field via the command line and want to use a dash in the description. What Langauge? MKS Integrity 2009.
    Is this running in a Linux command shell? If so, which one is it and have you tried a different one? I had seen something similar a couple years ago where commands run on AIX were not accepting dashes in the parameters.
