using Automation interface to 'Reconcile model'
I have a issue in using Automation interface to 'Reconcile model' using  vbscript error.
I am using below coomand but getting error( cannot use parenthesis when calling a sub):
Set objManager = CreateObject("Studio.ModelManager")
objManager.ReconcileModel("\\SQL\MyServer@MODELER\MyDatabase\MyModel\0.0.1","C:\MyLogFiles\MyLogFile.txt")
When i remove parenthesis,  get a error ( wrong number of arguments or invalid property assignment).
your feedback is appreciated.
PatrickOllerton
I've moved this to a new thread, it should not have been posted in the previous thread as it's not related.
If you have a Support contract, you can raise with them for assistance with this.
regards, Patrick
Here are some helpful articles:
The problem is not when i reconcile through 'Model explorer' but when i do it using Automation interface custom script . using the below VBS script. I am unable to pass two parameters. it says not to use parenthesis if i remove ,it says wrong number of parameters.
urgent!!
