Using CAC Card to login to Integrity
Question for Department of Defense users/administrators of MKS/PTC Integrity.
Have any of you been able to configure MKS Integrity to authenicate using your CAC card? If so, how or what did you do to make it work? I need help. Any help would be greatly appreciated.
Presently we are using the MKS Domain as our security method. It is a pain when you have hundreds and hundreds of users.
We are currently running MKS Integrity 2009 SP5 on AIX. We are planning to upgrade to 10.x in the future.
Thank you,
Dan
    Hello Dan,
    This enhancement is not currently available, and is covered by RFC 115502. Please contact PTC Integrity Support to be associated with this enhancement request.
    Having said that, apparently it's possible to use CAC with SiteMinder. I don't know the details of configuring that, but there is an article which explains how to configure SiteMinder for authentication with Integrity, or at links to the documentation for how to do that.
    Kael
    DanR.1-VisitorAuthor
    That is for Integrity 10.2 - 10.5. We are still on 2009. Maybe I could get our Integrity server upgrade done sooner. I will look into this solution. Thank you.
