Using PTC Integrity 10.7 where is the plugin for source code integration from Visual Studio
We are using PTC integrity version 10.7 and understand that this release supports a plugin from Visual Studio to PTC.  Can someone please tell me if this is downloaded with the Integrity Client or is it something else that has to be downloaded and installed separately.  We have found the Eclipse plugins which were deployed with the integrity client install.
    Hi Martin.
    You can find the Visual Studio integration for Integrity, under the "Software Downloads" section of the support site.  It's considered a "feature", so it will be listed under the "Features" sub-section, under the Integrity release you're looking at.
    We have this article published, which should help you:
    https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS120640&lang=en_US
