Jul 1, 2014 10:25 AM UTC
Webservice Strange "=" at webservice message
Hello i seem to be having a strange "=" in my soap header i am sending this
<SOAP-ENV:Envelope xmlns:ns0="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="http://webservice.mks.com/10/2/Integrity" xmlns:ns2="http://webservice.mks.com/10/2/Integrity/schema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Header/>
<ns0:Body>
<ns1:createItem>
<arg0 Type="Issue">
<ns2:Username>username</ns2:Username>
<ns2:Password>password</ns2:Password>
<ns2:ItemField Name="project=/ZI/O/project.pj"/>
<ns2:ItemField Name="Summary=Quick Summary"/>
<ns2:ItemField Name="Description=Quick description"/>
<ns2:ItemField Name="Issue Type=Change Package"/>
</arg0>
</ns1:createItem>
</ns0:Body>
</SOAP-ENV:Envelope>
    Jul 15, 2014 3:06 PM UTC
    Hello Sinea,
    Which "=" are you finding to be strange? Could you clarify what you need help with?
    Kael
    Sep 27, 2018 2:08 PM UTC
    Hi Kael,
    I get the fault responce as <ns1:MKSException class="com.mks.api.response.ItemModificationException" id="124251" implication="Unable to create item." xmlns:ns1="http://webservice.mks.com/10/2/Integrity/fault">Could not save item: MKS124251: Field "Project": Value "/XXXXXXXX=" is not a valid project.</ns1:MKSException>
    Sep 27, 2018 2:09 PM UTC
    I have used the same code for my purpose and received the following error message
    <ns1:MKSException class="com.mks.api.response.ItemModificationException" id="124251" implication="Unable to create item." xmlns:ns1="http://webservice.mks.com/10/2/Integrity/fault">Could not save item: MKS124251: Field "Project": Value "/ADC420HA10=" is not a valid project.</ns1:MKSException>
    Sep 28, 2018 12:11 PM UTC
    Hi @ptc-6234649,
    I wrote code for the same thing on my machine and it's working perfectly. Please take a look over the below code just change the value as per your system and requirement :---
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:int="http://webservice.mks.com/10/2/Integrity" xmlns:sch="http://webservice.mks.com/10/2/Integrity/schema">
    <soapenv:Header/>
    <soapenv:Body>
    <int:createItem>
    <!--Optional:-->
    <arg0 Type="Work Item">
    <sch:Username>lntuser</sch:Username>
    <sch:Password>lntlnt</sch:Password>
    <!--Optional:-->
    <sch:ItemField Name="Summary">
    <!--You have a CHOICE of the next 14 items at this level-->
    <sch:shorttext>
    <!--You have a CHOICE of the next 2 items at this level-->
    <sch:value>Created from web services</sch:value>
    </sch:shorttext>
    </sch:ItemField>
    <sch:ItemField Name="Project">
    <sch:project>
    <sch:value>/ASPICE_Demo</sch:value>
    </sch:project>
    </sch:ItemField>
    </arg0>
    </int:createItem>
    </soapenv:Body>
    </soapenv:Envelope>
    Please let me know in case you need any help.
    Vielen Dank
    Kapil Jain
    Oct 1, 2018 12:09 PM UTC
    Thanks , this works.
    Regards
    Hari
    Oct 15, 2018 7:56 AM UTC
    Hi @HariC,
    Accept the above as a solution so others may take it as reference.
    Vielen Dank
    Kapil Jain
