What is the expected/correct behavior for ROOT Documents?
Using documents we currently face some strange changes in be way PTC handles the “Documents” relationship in Segments.
As it seem impossible to find a manual/howto that fully describes how it is supposed to work I wrote down all case we can see currently in our system.
  • Create a new Document
    • Documen create…
    • Enter fields in Dialog
    • Set field “Root Document” to TRUE
      • >> field Documents contains the project backing item
  • Move a ROOT Document
    • Document Change Project
    • Enter fields in new Project
    • Ensure field “Root Document” is TRUE
      • >> field Documents contains new the project backing item
  • Branch a ROOT Document
    • Document Branch…
  • Change “Root Document” to false
    • Set Field “Root Document” to false
      • >> field “Documents” becomes empty
        • EVEN if the current User has NO project administrator permission
  • RE-Add a NON “Root Document” to Project
    • Set Field “Documents” to project backing Item (ONLY possible if the current User has project administrator permission)
      • >> field “ROOT Documents” stays FALSE
  • Branch a NON ROOT Document
    • Document Branch…
    • Ensure field “Root Document” is FALSE
  • Insert or Include a ROOT Document into another Segment
    • Content/Include/Document….
    • Select a ROOT Document from a project
        • ONLY if the current User has project administrator permission, otherwise
  • Insert or Include a NON ROOT Document into another Segment
    • Select a NON ROOT Document from a project
        • and cannot be modified, unless the current User has project administrator permission
Especially the last case leads to "lost" documents, as once included elsewhere, the document won't appear in a finder dialog anymore.
I am wondering whether I am the only one having issues with this.
Any reply wellcome
Hello Matthias,
quite interesting issue.
I can add that we have
a) aTrigger: MKS.ALM: Relate Root Document to Project
b) a Query: Top Level Documents
c) a Report: Top Level Documents (in Project)
If the behaviour you describe here has any meaning, was intended or not, I cant say.
My guess is that perhaps the ALM trigger is not covering all circumstances correctly?
Volker
