Windchill RV&S 13.0 - MS Word export filter traces to specific document IDs
Hi Windchill community,
I am currently facing the following issue. I am trying to export an ALM Requirements document to MS Word format using a custom gateway template. I am also exporting the "Decomposed From" field containing the traces to other documents.
What I want to do is to only export a sub-set of the traces per requirement. For example:
Requirement 1 in document to be exported has traces to:
Requirement A.2 in Document A
Requirement B.3 in Document B
Requirement B.4 in Document B
I want to use a filter that my export only shows the traces to Document A and filters all traces that point to document B. Is this possible using custom export templates? I have seen that traces have some properties e.g. the Document ID that they trace to but I am not sure if I can grab those in the word export template and use a conditional on it.
Michael
