May 27, 2019 6:20 AM UTC
With only node id, how can I get email address in user field on document belongs to ?
Hello
I would like to create trigger
in script I want to get email address in document's user field
trigger is triggered when node is changed, so I only know node id.
with this node id, I can get document's ID using API.
but I have a problem getting email address in user field on document.
below is my plan to getting user email address
(1)node(2nd level) ID -> (2)node(1st level) ID -> (3)document ID -> (4)user field list -> (5)user email address
I achieved only (3)
Thank you in advance
awalshAnswer
May 27, 2019 3:50 PM UTC
The previous script assumes that the node is being edited. If that's not the case, and you just have the ID, then you can get an Issue bean for the node ID rather than getting a delta bean:
// var nodeBean = bsf.lookupBean("imIssueDeltaBean");
var nodeBean = server.getIssueBean(1234,["Document ID"]);
where 1234 is the node ID.
May 27, 2019 3:40 PM UTC
You will need to get an issueBean for the document to see the user field info, then a userBean for the user to get the email address.
Sample script that just looks up the user email and prints to the server.log file:
var eb = bsf.lookupBean("siEnvironmentBean");
eb.setMessageCategory("GENERAL");
var server = bsf.lookupBean("imServerBean");
var userfield="Assigned User";
var docID=nodeBean.getDocumentID();
var docBean=server.getIssueBean(docID,[userfield]);
var username=docBean.getFieldValue(userfield);
if (username != null) {
var userBean=server.getUserBean(username);
var userEmail=userBean.getEmailAddress();
eb.print("The email address for " + username + " is " + userEmail);
} else {
eb.print("The user field " + userfield + " is empty on Document " + docID);
I ran this as a pre-trigger with the rule "Type=Requirement", and here's the server.log output for different values of the user field:
2019-05-27 11:35:27,586 INFO [mksis.IntegrityServer] GENERAL(5): awalsh[RMI Executor-thread-8]: Trigger "useremail.js" - The email address for awalsh is awalsh@test.com
2019-05-27 11:36:57,072 INFO [mksis.IntegrityServer] GENERAL(5): awalsh[RMI Executor-thread-3]: Trigger "useremail.js" - The email address for business_analyst is null
2019-05-27 11:38:53,074 INFO [mksis.IntegrityServer] GENERAL(5): awalsh[RMI Executor-thread-6]: Trigger "useremail.js" - The user field Assigned User is empty on Document 1382
awalsh5-Regular MemberAnswer
bson2112-AmethystAuthor
Jun 2, 2019 11:13 PM UTC
Thank very much
your advice is very helpful for me Smiley Happy
