Sep 5, 2017 10:12 AM UTC
Controlling access to Integrity Modeler license features through the flexlm options file
  • If there are 2 PLE licenses available how can it be controlled which users can access those licenses as the default is to take the license so the first 2 users take the licenses unless they specify not to take the license? This prevents the specialist variability Modeling users access the editor licenses.
  • The method in this video uses the Flexlm options file to control who can use these features:
Sep 5, 2017 12:35 PM UTC
Solved the problem easily using this method - also can be used for other areas which have limited licences. The name to use in the opt file (ART_PLE in the example) can be found in the artisan.lic file
