Oct 22, 2015 10:45 AM UTC
AutoIT Hole UI Scripts you may find useful.
In my work I create a large amount of threaded holes in my designs and the hole placement UI can be a little tedious.
To solve this, yesterday I created two rough AutoIT scripts that simplify my hole workflow by selecting my most common parameters.
I need to modify the thread depth to a formula to allow for clearance, but at the moment they match the thread depth to the hole depth.
They can be called through mapkeys that I have placed on my ribbon.
They work on Creo 3.0, with tweaking I am sure they will work in other releases.
I would just like to share these with anyone who may find them interesting or even put them out there to be tidied or improved upon.
I am far from being any kind of coder but I am happy to explain how they work and welcome your feedback.
Enjoy
Miles
Oct 23, 2015 10:51 AM UTC
Miles,
I was curious about your scripts, so I downloaded them and tested on PC with 22'' monitor with 1680x1050 resolution.
1.] AutoIt v3.3.10.2 is installed on my PC.
2.] Creo Parametric 3.0 M060
I had to slightly modify scripts, because my AutoIt installation does not contain AutoItConstants.au3.
I added:
#include <Constants.au3>
$MOUSE_CLICK_PRIMARY="primary"
3.] Creo Parametric 2.0 M180
Again I had to slightly modify scripts, because of different window title.
Creo 3.0 ... PTC Creo Parametric
Creo 2.0 ... Creo Parametric
MH
Oct 23, 2015 12:58 PM UTC
Hi Martin,
I have AutoIT v 3.3.14.2 installed that will explain the #include being incorrect.
What are your thoughts on the execution of the script? A counterbore has gone from 9 or more clicks (depending on thread) to 4 (2 if you want the default of an M5 C'Bore)
It saves me so much time now and reduces errors from missed or forgotten clicks.
I hope they could be useful to others or even inspire others to streamline their own workflow. 🙂
I guess TOOLKIT could be utilised with greater affect but I do not know how it works.
Miles
Oct 23, 2015 1:21 PM UTC
Miles,
1.] TOOLKIT programming is activity reserved for specialist - programmers. It cannot be used by amateurs -  for example me .
2.] To save clicks, you can implement saving lastly used values into file. When launched next time, script can read this values.
MH
Oct 23, 2015 2:43 PM UTC
how did you connect the script with the icons, did you create two mapkeys using "os script"?
If so, how exaclty has the line to look like in order to work?
Andreas
Oct 23, 2015 3:24 PM UTC
Hi Andreas,
You are right, I did create 2 mapkeys using OS Script and placed them on the ribbon.
I copied the hole icon and modified it to give me a good visual icon.
The os script looks like this in the config.pro file:
mapkey 02auto @MAPKEY_NAMEAutoIT Script Threaded Hole;\
mapkey(continued) @MAPKEY_LABELThreaded Hole;\
mapkey(continued) @SYSTEM"C:\\PTC_ConfigFiles\\AutoIT_Scripts\\Thread\
mapkey(continued) ed_Hole.au3";
mapkey 03auto @MAPKEY_NAMEAutoIT Script Counterbore Hole;\
mapkey(continued) @MAPKEY_LABELCounterbore;\
mapkey(continued) @SYSTEM"C:\\PTC_ConfigFiles\\AutoIT_Scripts\\Counte\
mapkey(continued) rbore.au3";
Or like this in the mapkey UI
Miles
Oct 26, 2015 9:43 AM UTC
Hi Miles,
thanks for the answer, this is what I was expecting.
Andreas
Oct 26, 2015 9:31 PM UTC
That's nice, usually people don't share that kind of stuff here.
But to achieve that you can also use a UDF with a mapkey.
The number of clicks will be the same but you'll have some advantages:
  • Internal commands, not Keystrokes, so more more consistency.
  • More easy to create and modify
  • you can replace the already inserted hole with another one with another dimension (with a family table)
  • Udf canl bring colors too, if that's important for you.
Just my 2 cents:)
Jose
