Automatic Selection of all surface between two surface
- 1 reply
- 3564 views
- Translate All
Hi All,
I would like to automatically select all the surfaces (1,2,3,4) between two highlighted surfaces ( 1 & 4 , See attached image) in creo. The thing is I don't want to select all four surfaces individually. Is there any command or any way where I need to select only 1st and 4th surface and creo would select all surfaces in between automatically?
Your help would be highly appreciated.
