Show both dimensions on drawing and set tolerance for each. Click outside the view to deselect everything. Hover the mouse over the angle dimension to determine it's name (e.g. d13). Select the distance dimension and add the angel dimension to the dimension text (e.g X &d13). Lastly, erase the original angle dimension.
