Dec 11, 2015 8:48 AM UTC
Compare drawings in creo view
Hi all,
I found an option of comparing two drawings (.drw) using creo view in a website.
Kindly can you walk me through step by step.
I tried doing in clipboard but it didnt work
I have to compare 2 drawings latest revision with old revision.
Thanks & regards
Vivek Rajan N
Dec 11, 2015 9:09 AM UTC
This article describes the process: https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS49628
I think it is important that you use the MCAD version of Creo View, which is licensed, set this in Options → General → StartupCreo View Options.PNG
Then copy both versions of the drawing to the clipboard, open the clipboard, select both drawings and click Open in Creo View.
Click OK in the Annotation Setting box if it appears.
In the viewables tab, select both drawings, right click and select Compare Selected.
Then you should see both drawings overlaid on each other.
Hope this helps
vrajan10-MarbleAuthor
Dec 11, 2015 10:46 AM UTC
Thanks for the reply David. Will check and come back to you
