8-Gravel
August 8, 2022
Creo 6.0 Appearances Library - colors too dark
  • August 8, 2022
  • 4 replies
  • 4553 views
I am using Creo Parametric - Release 6.0 (connected) Release 6.0 and Datecode6.0.4.0
Colors in Appearances library appear much darker than they are supposed to be. I have already read thorough CS328931 and troubleshot graphics card. Other users in my organization have similar hardware but don't encounter the same problem.
    Best answer by MartinHanak
    @Tiago_Denczuk wrote:
    I am using a Dell laptop with UHD Graphics. This configuration is not shown as Certified and Supported. That said, other people in my team are using similar hardware and don't have the Appearances issue.
    sometimes the problem can be resolved by installing older graphic card drivers. Try installing 1 or 2 year old drivers and let us know.
    Your appearance gallery display darker colors than expected and the article 328931 suggests that this is caused by the option graphics set to win32_gdi.
    One way to check that is to display your display information like so:
    Can you paste your and confirm that the line Creo Parametric Graphics Type shows indeed : OPENGL
    By elimination this will confirm the article does not apply to your situation.
    8-Gravel
    August 9, 2022
    Graphics Type is indeed OpenGL.
    The only thing not supported is OpenGL Frame Buffer. I don't think that this should be causing the issue:
    About the Frame Buffer, try the option  enable_opengl_fbo yes.
    FYI ... in my notebook there is Intel UHD Graphics 620 and I can see the same "problem" when using OPENGL in Creo. The root of this problem is incompatibility between graphic card and Creo.
    8-Gravel
    August 9, 2022
    Here is to understand what Certified and Supported entile: http://support.ptc.com/partners/hardware/current/status.htm
    StephenW
    @Tiago_Denczuk
    My problem was with a config setting although I could never really explain why
    pro_texture_library
    or possibly
    texture_search_path
    https://community.ptc.com/t5/3D-Part-Assembly-Design/Why-are-all-my-appearances-dark/m-p/299194
    8-Gravel
    August 9, 2022
    @StephenW
    Unfortunately that solution didn't work for me.
    StephenW
    To eliminate your config.pro/config.sup/customization, close creo and temporarily rename the following files
    config.pro
    config.sup
    creo_parametric_customization.ui
    Relaunch Creo, if the problem goes away, there is an issue in your configuration settings.
    If the problem remains, it is somewhere besides your settings.
    Don't forget to rename the files back after testing.
