Creo Parametric Community Challenge 4 - Additive Manufacturing
- 10 replies
- 4626 views
- Translate All
This month’s challenge is based on 3D printing and Additive Manufacturing. Your challenge, should you choose to accept it, is to lighten a part model by replacing a solid section with 3D beams or 2.5D lattices.
If you have the Additive Manufacturing module, you can use the Lattice feature. If you do not have it, how do you model beams with standard Creo features? What combination of Extrudes, Patterns, or other features would you choose?
You can create 2.5D lattices or 3D beams of your choice. You can create triangles, squares, hexagons, or octagons (or more). If you make 3D beams, you can add balls at the intersections of the beams if you want to. If you have the Additive Manufacturing module, you can make formula-based or custom lattices. Express your artistic side.
You can use a model of your choice, or you can use either or both of the Creo 4.0 provided models. One has a rectangular section that can be replaced; the other has a cylindrical section. You can create the beams inside a shell, or you can leave them exposed for easier viewing.
This challenge closes on Friday, February 16th. Show us how you model for 3D printing and Additive Manufacturing!
Find the PTC Creo Community Challenge Guidelines here!
