Dale_Rosema
May 12, 2023 1:45 PM UTC
Cursor not visible in family table cell
When editing a family table cell, the cursor goes AWOL (missing) and I have remember how many left or right arrows to edit text in a cell. I am using Creo 9.0.4.0.
Has anyone else experienced this?
Any thoughts to a solution.
Brand new systems with the specs called out for Creo 9.0.4.0.
Dale_Rosema
Jun 19, 2023 2:52 PM UTC
Waiting for the next release:
May 12, 2023 2:03 PM UTC
in Creo 9.0.2.0 I can edit FT without problems. See video. I guess Creo 9.0.4.0 should work the same way.
Dale_Rosema
May 12, 2023 2:10 PM UTC
Can you check and see if when you are in an active cell and you press "F2" to edit the cell if the cursor shows up?
Then use the right and left arrows, too.
May 14, 2023 8:30 AM UTC
Q: Is text cursor displayed in active cell after hitting F2?
Creo 9.0.2.0 ... no
Creo 8.0.4.0 ... no
Creo 7.0.9.0 ... yes
Suggestion: I you have Excel installed then edit FT in Excel.
Patriot_1776
May 12, 2023 3:32 PM UTC
'Sup Dale!  I'm on Creo 8, but it may be a Windows thing.  We had issues with there not being a cursor on our "Red" systems, and it turned out to be windows settings (Use text cursor indicator)  and (Cursor blink rate).
Best of luck!
Dale_Rosema
May 15, 2023 1:19 PM UTC
I opened a case for cursor disappearing when editing a family table using "F2" key.
Case 16880414 has been opened
Dale_Rosema
May 15, 2023 7:51 PM UTC
The missing cursor was replicated by PTC customer service and the issue has been reported to R&D as SPR 14609846.
Dale_Rosema
May 25, 2023 4:23 PM UTC
Another discovery:
When editing a cell in the family table using F2, if you Alt-Tab to another item you have open and then Alt-Tab back, the cursor is present and blinking.
Weird!!!
