Custom hole file for drilled holes?
- 2 replies
- 1320 views
- Translate All
Is it possible to create a custom hole file (.hol) for holes that are only drilled, not tapped? I'm trying to recreate a standard drill chart with our standard countersink sizes and hole callouts.
For the life of me I cannot figure out if Creo will allow me to do this. I have a number of custom threaded hole files but this one is an enigma.
What I have so far is attached. When I go to select a size from it, I just get a -1.000 for the diameter. Remove the .txt if using the file.
Thanks..
