Dale_Rosema
Entering text in a note on a drawing.
  • November 4, 2021
  • 4 replies
  • 3720 views
I am in the process of testing a Stream Deck XL for improvements in office automation. A large ECO needs a note added. I put the text in Stream Deck so that when I open the text dialogue box it would enter the text.
Here is the text:
Here is what I end up with in Creo.
Is this a font issue or something else?
If I copy and paste it from another drawing, or even from the text in the stream deck it works.
Dale
Could be a formatting issue with embedded characters in the Stream Deck file. I know Word files do not always cut and paste directly as they contain embedded control characters in their formatting.
do you mean following device ?
https://www.elgato.com/en/stream-deck-xl
Dale_Rosema
Martin,
Yes, that the devise. I use it for live streaming at my church and can call camera presets, scenes, publish them to the stream.
I was thinking that it might be useful at work and wanted to try it out on a couple of things: Creo, MasterCAM, Excel, ....
That was my first attempt with Creo. It seemed like a relatively simple task.
Dale
Patriot_1776
NOTHING is ever a "Simple Task" in Creo...🤣🤣🤣
I recommend putting the text into a mapkey and having the stream deck trigger the mapkey. Or you can run the mapkey from your keyboard.... Or a full secondary keyboard. I made some setup files to do it buts it's much more to learn and more software. Hidmacros and autohotkey. Shame I can't install on my Work computer or I'd develop script for it more.
You can also append/add text from from a file. Which again can be setup to trigger from a mapkey.
Dale_Rosema
Elgato asked to check it out in other software.
Word works
Excel works
Office works
Draftsight works
ProCam works.
But not Creo. Neither in a text box or at the command prompt.
I have a SD XL, and it works fine for map keys.
I'm using this.
It paste all my boring map keys...
Even with "Enter Key" so several Map keys...
Sorry, screenshot is in French...
