May 19, 2021 3:53 PM UTC
Hiding specified value in a BOM
I'm just looking to hide the value of a specific parameter value in my drawing. For example, something along the lines of
if asm_mbr_cagecode = "2233"
then asm_mbr_cagecode="    "
I have a few parts in my smart BOM that need this parameter hidden if they are a certain value.
May 20, 2021 9:26 AM UTC
in repeat region relations you cannot change model parameter values.
Use relation similar to following:
IF asm_mbr_cagecode = "2233"
my_cagecode = " "
ELSE
my_cagecode = asm_mbr_cagecode
ENDIF
And put &rpt.rel.my_cagecode in the table column.
my_cagecode = " "
ELSE
ENDIF
kspabs1-VisitorAuthor
May 20, 2021 6:17 PM UTC
I have run into an issue when adding this relation. I have a split BOM, with the relation:
myindex=rpt_index+53
With the column parameter: &rpt.rel.myindex
After adding the cagecode relation my find numbers and quantities have broken. Entries that have been manually fixed to a value, the Find No and Qty have gone blank since adding the cagecode relation. Any clue why?
May 20, 2021 8:05 PM UTC
Awesome, this is great to know. I've only been working on Creo for a little over 2 years and it isn't too intuitive so I have a lot to learn still.
EDIT:
So even doing this on a brand new BOM table, it is still breaking the find number and qty on hardware in my table. Any clue?
Fixed this by changing the paramter FROM rpt.rel.num TO rpt.qty
