How do you hide construction lines in drawing
  • November 21, 2016
  • 16755 views
I need to have construction lines to get intersections and dimension placements on a drawing but I can't seem to find how this is hidden.
I do however have a few solid lines and arcs that I would want displayed on the drawing.
Is there a way to filter by construction entities and blank these on a drawing?
Best answer by MartinHanak
you published picture of your drawing. Unfortunately I do not understand how construction lines were created. Are they draft entities created in the drawing ? If this is true, then hiding them using layer is the only way I know.
MH
can you upload some example data and pictures showing what you want to hide ?
MH
pimm15-MoonstoneAuthor
Martin
Here is a view of the type of entities I would like to hide.  See the type arrowed in green.
Since my post I have discovered that I can make a new layer to the specified entity type and specifically hide this.
Is there an easier way?  I would prefer to select all of a type and just right click hide, but that isn't possible that I can see.
I'm curious what you feel would be easier?  You want them to continue to exist, and not to be shown, and layers are the usual way of doing that.  Presuming you made a default layer for construction entities (or make a layer by rule or by mass-selecting with Find dialog or drawing tree if you hadn't yet), hiding them is quickly done.
I'm interested in any suggestions that might improve the product, or possibly just the way it's presented -- it's a large and complex program, and it's hard for a person to know all the settings that might optimize their workflows.
