How to delete parameters from Notebook files (ex Layout)?
Dear users,
I am very new of PTC Creo (in the past I used other CADs) but actually I am using Creo 3.0 M050.
I am designing an assembly with the Top/down technique: the components and sub-assemblies are driven by parameters defined in a Notebook file (in Creo 3.0 it is still called Layout file).
Obviously, during the work, I did some tests and now my Notebook file presents obsolete parameters.
These parameters are no longer used in any part file, but I can not delete them (in the Tools ------> Parameters menù of the Notebook file).
If I try to delete a parameter that is used in a part (called for instance "xxx") of the main assembly, I get a message that that parameter refers to part xxx (rightly!).
If I try to delete an "old" parameter, the message reports that this parameter refers to the Notebook file and so I can delete it; but this does not seem logical to me, because it is a redundancy.
How can I then delete the parameters defined in a Notebook file? Obviously, not being used in any relationship, I could also keep them, but I would like to have a clean and tidy file!
Thank you so much for the help,
IG
