How to open (import) multiple STL files at once in PTC Creo Parametric?
  • April 12, 2021
  • 5 replies
  • 3629 views
I can open STL files one by one but each time I open a different STL file Creo opens it on a new page. I want to open all STL files on a single page with a single operation. How can I do that?
Chris3
As of Creo 7, Creo does not support opening multiple files with a single interface. It can be done through a workspace in a linked (Windchill) environment or it can be done with a mapkey.
To do the mapkey route, record a mapkey opening the file (the mapkey code changes with each Creo release). Then save the mapkey file and copy/paste the code over and over and change the filename to correspond to each file you want to open. This may be more effort then just opening them one by one.
Mapkey tips here:
https://community.ptc.com/t5/System-Administration/Mapkey-Writing-Editing-Tips/td-p/443729
What do you mean by 'on a single page'?
Creo will open each step file into a new Creo file. If you want to open them into a single file, use the import command.
If you are trying to import an assembly, Creo should handle that as long as the step file is of the assembly.
If you need to build an assembly of your step files, open them all as individual Creo files and then create a new assembly file and assemble the components.
Dale_Rosema
He is mentioning .stl file not .stp file. Not sure if this makes a difference.
