Mechanism: Set 'Max Limit' using a Parameter
- 4 replies
- 6390 views
- Translate All
All,
I have a simple sub-assembly with a sliding mechanism constraint. I want to alter/set the 'maximum limit' of my constraint using a parameter. I want to test 2 conditions, one where the slider moves between 0 and 300 and another where the slider will move between 0 and 500. If I could control the max limit with a parameter I could switch between conditions easier than editing the constraint.
Is this possible?
Mike
Creo 4.0
