Jun 11, 2014 6:25 AM UTC
Problems in cabling (flatening, documentation)
I am working on Cabling assemblies. I have layout of the wires on my assembly connecting different entry ports of different connectors to differentdentry ports of diffeternt other connectors following different networks or manual routings.
Problems i am facing are :
1. During flattening of the harness, when i fan out the cables to the connector it gives an error " insufficient wire length" I am unable to understand how to remove this problem.
2. In some cases we need to drop wire on a connector from both sides of the connectors as shown in the image. But when we flat the model we are unable to terminates the wires on same point, rather we get two segmants that do not terminate on same connector.
3. when in creat the from-to table of the wires it does not automatically poputale. I need a table that contains the details of all the wires i.e length of wire, starting connector, starting port, termination connector, termination port, etc
Best Regards
Muhammad Usman
Jun 11, 2014 10:52 AM UTC
Muhammad
1) Remove the connector, then re-attach the connector to the shortest segment - As a side note routing all the conductors to a single csys and using the def_internal_len parameter will negate this problem
2) Send to tech support for investigation
3) Use attached table
Jun 12, 2014 6:01 AM UTC
Thanks for your Reply Jim,
I have already tried to remove connector and to attach it to shortest length of the wire connected to it.
You said i should rout all the conductors to a single csys. But Connectors in my harness assembly are 9 pin , 15 pin, 37 pin, 50 pin, 78 pin connectors. I have made the csys on all the pins e.g 9 pin connector has 9 csys and 78 pin connector has 78 csys. every wire is connected to diffrent pin/entry port. When i designate the connector, i select all the csys as entry ports and enter 6mm when i m asked the length inside the connector.
Can you please share some harness work with me so that i may correct if i have done some other mistake.
In the PTC training files for cabling extension i could not get the answer to "insufficient lenght " problem
Best Regards
Muhammad Usman
2-Explorer
Jul 24, 2014 5:07 PM UTC
Regarding the insufficient length:
Creo always attaches the connector to the shortest wire/cable, because this maximizes the chance that the other wires (which are longer) can fan out. However, if the longer wires need to reach more distant ports, this simple strategy may fail.
What you can do, is adding two or more bends to the shortest cable, to reduce the distance between connector and the failing cables until the other cables can be fanned out.
Jul 15, 2014 5:23 AM UTC
Try and make your main network like this
Rout a branch in 1 point instead of 2 points
Jul 17, 2014 1:40 PM UTC
In your case both side of wires (top & bottom as per picture) were creating closed loop. Move your flatten wire segment nearer to unflatten portion then try closed option.
---Ram
