Render Window - Black Background
  • February 23, 2010
  • 8155 views
Hi, I have barely touched on rendering in ProE, but I like the way the product looks 'smoother' after a simple render using the 'render window' button. This would be good for screenshots, but after rendering the window, the product is fine, but the background is black. How do i get a white background?
Under render control set the settings to high or maximum, if you leave it at draft you will get a black background. maybe that what you are referring to.
Now when set to draft, it's not coming up a black background. ????.......crazy......I have no idea The first five times I set it to draft, it came up as a black background, now it's not.
