Repeat Regions & Representations
Hello everyone!
I've been trying to create a repeat region BOM that will load characteristics from multiple simplified representations of the same model. For example, check out this chart below displaying an assembly with 3 simplified representation variants.
Part numberPart DescriptionIndexSimp. Rep 1Simp. Rep 2Simp. Rep 3
&asm.mbr.userparameter&asm.mbr.userparameter&rpt.index&rpt.qty&rpt.qty&rpt.qty
12345Square peg1111
98765Plate with round hole2101
12398Hammer3110
I've found one file in our entire system that is somewhat similar to what I want, but it looks like it was created in Pro/E.
Here's a picture of what I've got from the old file. The part circled in red can only be seen if I highlight the cell (displayed behind rpt.qty) or if I change the text style. When I type that same value ( to at the very least try to re-produce the same result ) into the extra column I've added on the far side, I get the error shown. Clearly, it recognizes the language and the functionality but does "not allow it".
Was this functionality disabled in Creo 2.0? Any ideas?
-Adam
Mahesh_Sharma
22-Sapphire I
Adam,
Check attached video, I hope this will help you.
Mahesh_Sharma
22-Sapphire I
Adam,
awaters1-VisitorAuthor
Thanks Mahesh!
-Adam
