Replace Component By Family Table - Family Tree Show Table by default
Does anyone know if there is a config.pro param that can be set to Show Table by default when Replacing a Component by Family Table in an asm?
Here's a mapkey that you can start from. You'll need to replace the bold text with the parameter name that you want to show in the table.
!!!REPLACE SELECTED BY FAMILY TABLE
mapkey RFT @MAPKEY_LABELREPLACE SELECTED BY FAMILY TABLE;\
mapkey(continued) ~ Command `ProCmdReplComp@PopupMenuTree` ;\
mapkey(continued) ~ Activate `gen_repl_dlg` `PB_NewComp`;\
mapkey(continued) ~ Activate `mdlbrowser` `SwitchCol`;\
mapkey(continued) ~ Update `column` `InpName` `desc`;\
mapkey(continued) ~ Activate `column` `AddBtn`;\
mapkey(continued) ~ Activate `column` `OKBtn`;
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
