Symbols missing from dimension text pallet
  • August 21, 2024
  • 3 replies
  • 2166 views
I have changed the detailed options for symbol_font to ASME and the additional symbols show up in the GD&T and Notes area however, the dimension text does not have the full list of symbols. How can I get this to update? The specific symbol I'm looking for is the spotface symbol.
We're using Creo 7
I fixed my issue... Even though I was creating a drawing owned dimension I needed to set the symbol font in the model as well
spotface symbol is not available. You have to define Creo symbol to fill this gap.
https://www.gdandtbasics.com/spotface/
StephenW
Spotface was added in creo 7. I use Creo 6 and it is not available.
I do also have creo 11, and spot face is available.
8-Gravel
October 7, 2024
We also ran into this.  However, we found that if we just reset the default, ASME, that we would get the full pallet.  It works in that I can now see the full pallet, but I didn't change anything and ASME is the default.  Anyone else experience this?  Seems like a bug.
