how to hide the center line of a pipe in a drawing?
  • December 26, 2014
  • 4 replies
  • 8948 views
i just created a pipe drawing in creo2.0 and i want to make the drawing without centre line of it.
Best answer by StephenW
The way I hide the centerline is I add the pipe feature(s) to a layer and then turn off that layer in the drawing. Creo won't hide the solid geometry when you add the feature to a layer but it will hide the centerline. Don't forget to save layer status in your drawing once you hide the layer.
StephenW
StephenW23-Emerald IIIAnswer
viswarya1-VisitorAuthor
thank you verymuch stephen
