Dec 28, 2016 2:12 AM UTC
how to turn on neon effects for selected feature or dimension lines
As captured picture below, how can I turn on neon effects for selected feature or dimension lines?
Thank you.
wchegalAnswer
Dec 29, 2016 12:39 AM UTC
You can turn on this option by inserting the following line in config.pro
enable_selection_glow yes
Thanks to James Lim in Digitek for giving this tip to me.
wchegal1-VisitorAuthor
Dec 28, 2016 2:20 AM UTC
Dec 28, 2016 7:59 PM UTC
Interesting... we have neon?
Dale_Rosema
Dec 28, 2016 9:47 PM UTC
Highlighted? (translation?)
wchegal1-VisitorAuthorAnswer
Patriot_1776
Dec 29, 2016 1:14 AM UTC
Interesting, I'm on creo 3 and that option doesn't show up
Dec 29, 2016 1:31 AM UTC
It is a hidden option. Just type it in your config.pro with text editor.
Dec 29, 2016 5:26 PM UTC
Works in Creo 2 as well, at least in M230.  Not sure how I feel about it, but I'm going to give it a shot.
Patriot_1776
Dec 29, 2016 7:15 PM UTC
I haven't used it much yet, but am liking it.  These old eyes need a little more highlight.
I posted all this here at work for all the ex-SW users now using Pro/E, maybe that will eliminate SOME of the whining....
Patriot_1776
Dec 29, 2016 10:20 PM UTC
Ok, so, I wasn't able to see any change in drawing mode, though it was a quick check.  where I think I like it the most, is in sketcher mode.  It REALLY highlights constraints, sketched entities, and other objects well.  Again, just a quick test in sketcher, but I think I like this setting!
Dec 30, 2016 7:13 AM UTC
For those that are using neon effect here are some extra neon display control options:
glow_blur_radius     1
glow_blur_sigma     internal
glow_blur_type        internal
glow_line_width      2
Patriot_1776
Dec 30, 2016 2:41 PM UTC
The problem with hidden configs, is that there is no explanation as to what they do.  I tried the above configs, and didn't like them.
Dec 30, 2016 4:16 PM UTC
glow_blur_type:
  • 1 fading glow, further from line, less intense
  • -1 flat glow, more like a wide-transparent flat line behind selected object  (my preference now)
glow_blur_radius:
  • width of the blur, but is dependent on the glow_line_width
glow_line_width:
  • width of the base highlight line that is blurred.  when blur-radius = 1 the selection will be wide and opaque.  when blur-radius larger, the glow-line will be more transparent but the wider the line_width the more opaque the highlight appears.
glow_blur_sigma:
  • [edit] default value was 6.3.
  • 0 gives no highlight
  • 1 barely any glow, only a thicker line
  • 3 starts to show a glow
  • 6 default look
  • 12 getting toward a more flat look
  • 24+ gives same basic effect to the glow_blur_type -1
sigma adjustment from 0-24+
Some examples of different values when changed.  Also note, I have my "selection color" set to a neon green because the magenta selection color is not as "highlighty" to my taste.
