missing holes in hole table
I have a part that has 5 M3 x 0.5 tapped holes. Only 4 of them show up in the hole table I created in a drawing.
I have deleted and recreated the hole table several times. Same result.
Ankana43Answer
Try this one.
Thanks again
What software and version/build?
What does this have to do with a Data Exchange issue?
Please be careful and place your questions in the proper category!
Ankana431-VisitorAuthor
Pardon me, I'm new to this forum. Didn't mean to violate protocol.
Check to make sure that all of your holes are created on the same surface as the origin of the hole table. If you have holes going in from top and bottom and the origin is created with the top surface as a reference, the hole table will only show holes that go in from the top surface.
We avoid hole tables for this reason...
Mahesh_Sharma
22-Sapphire I
@@Ankana43
Can you share file for review?
Here are the files involved. there are 6 M3 x 0.50, only 4 show up on the table. I have tried deleting and replacing the holes among other things. The problem seems to be related to location? Also, do you know of a way to enter other than the default decimal places not all holes require 3 place decimal, I would like some of them to be 2 place decimal. I'd like to be able to add tolerances to a few of them also. Thanks in advance for your help.
Mahesh_Sharma
22-Sapphire I
Unable to open drawing as it is reporting for missing mrf-07-171-02_brkt_carr_pln/mrf-07-171-03_brkt_carr_pln/mrf-07-171-04_brkt_carr_pln
