"Invalid value" error when creating a parameter with a list of restricted values.
I am using Creo 9.0.5.0.  Like the title says, I am trying to create a few parameters with a drop-down list of values.  Basically exactly what this video is doing: https://www.youtube.com/watch?v=kzvw8wfwavc
I am getting an "Invalid value" error when I try to create this list and I am not sure why.  What might I be doing wrong?
Matt
I got it ...
After defining values on Definition tab you have to switch to General tab and set parameter value in Value field. Only then you can click OK button.
Creo 9.0.2.0 ... I reproduced the problem
Creo 7.0.5.0 ... no problem
Suggestion: Report the problem to PTC Support.
I got it ...
