Dale_Rosema
"Printing PDF"s vs "Save As" pdf - which is better
  • August 10, 2022
  • 3 replies
  • 8709 views
Late to the game of printing/saving pdf's. Is one of these better than the other? Or do they do the same thing?
Best answer by BenLoosli
They are different. You need to do a test of each option and compare the printed results.
The Save-As uses internal code to create the PDF. The Print option uses the system PDF printer code.
BenLoosli23-Emerald IIIAnswer
Dale_Rosema
Thanks for the heads up on differences. One thing so far, how do keep a number centered inside a balloon when "Saving As"
Saving As
Printing
StephenW
I use "stroke all fonts". It usually gives a better looking PDF.
StephenW
I prefer to print to PDF. Others in my company uses the save as/export option.
Years ago, when we first started generating PDF files, the save as option would crash on my large assemblies. So I'm biased by my experience. I've tried it since and it doesn't crash anymore but I can't get over my preference! I do have my setup well defined for print to PDF so its just easier for me to continue using my method.
Dale_Rosema
Same but new question:
What's the difference between SaveAs and Export?
SaveAs let's you choose the file type (PDF), set the file name, then change any of the PDF settings.
Export puts you into a preview mode and requires you to manually open the PDF settings if you want to save them before setting the file name and exporting.
As far as I can tell, there is no difference in the file created, it's just a different workflow and whether or not you want to see a preview before saving.
Dale_Rosema
I would like to thank everyone who help me learn the difference between the various  .pdf outputs the last few days:
@BenLoosli
@TomU
@StephenW
Patriot_1776
'Sup Dale!  I usually create a PDF with truetype fonts (Arial), and print that from Adobe.  It seems to work out well.  Best of luck!
