3-Newcomer
Dec 12, 2023 8:55 AM UTC
solidify
- 3 replies
- 4821 views
- Translate All
I would like to add thickness to an imported surface in creo to make it a solid model. I couldn't do it with the Thicken command because the shape is too complex and some surfaces can't be offset so I built the inner surface with less offset. I managed to merge a model with an internal thickness of closed surfaces, but the solidify command won't do it because the surface connection is not watertight. In the surface connection analysis, it shows red in a few places and the maximum gap is 0,035 mm. My question is, how can I set it to ignore these small errors and do the solidify command?
