sweep protrusion using 3d curve
- 9 replies
- 7143 views
- Translate All
I want to use "insert sweep protrusion" using a "3D" curve as the trajectory.
I have in the past always done this with intersected curves, but sometimes that's a lot of work.
I thought this would be easier if I just defined a set of points and put in a curve using them.
I defined a set of points using Offset Coordinate System Datum Point Tool.
Then I put in a curve using "through points".
When the points are all co-planar (on the YZ plane in my pictures), the Insert Sweep Protursion command accepts the curve
and the protrusion comes in fine.
Once I make the points and curve not co-planar, ProE will not accept the curve as the trajectory and gives the message
"Specified trajectory is not valid. Please reselect."
This really sucks.
Is there any way to get ProE to accept the 3D curve without having to do intersected curves?
