Apr 5, 2016 5:22 PM UTC
Eliminating Linker Warnings with OTK C++
I revisited the sample OTK C++ program named otk_install, which I hadn't looked at in about 2 years. I discovered, once again, that I couldn't build a DLL without provoking linker warnings 4049 and 4217. It's not just one or two of these warnings, either; I received 104 warnings for the tiny amount of code in otk_install.
PTC seems to be aware of this problem, because their OTK C++ make files include these linker options:
/ignore:4049 /ignore:4219 /ignore:4217
I haven't been able to do better. All of my current code that uses OTK C++ also includes these options.
I don't like suppressing warnings. When you do that, you don't know whether the warning is happening only once or a thousand times. I nearly always believe that there will be consequences one day for hiding the warnings instead of addressing them.
Microsoft states that these warnings carry only a (presumably minor) performance impact:
Although the final generated code will behave correctly, the code generated to call the imported function is less efficient than calling the function directly.
...but given that I received 104 instances of these warnings, I have to assume that there could be as many (or more) invocations of the affected functions.
I have noticed these warnings when building DLL's, but not EXE's. Of course, I use DLLs for my synchronous applications.
Has anyone successfully built a DLL in OTK C++ without provoking these warnings?
|+|  M a r k  |+|
FV_01
Apr 6, 2016 1:26 PM UTC
Hi all,
Mark, to my knowledge, OTK classes quite often are wrappers for Pro/Toolkit C style functions. C and C++ approach to import/export of symbols is not the same, hence the warnings.  In ideal world OTK would be a nice and shinny, pure C++, C14 compatible set of libraries with no warnings whatsoever...
Feliks.
Apr 6, 2016 5:01 PM UTC
Feliks -
This, by itself, should not be a problem:
I have also written C++ wrapper methods to call Pro/Toolkit functions, but I never got these warnings.
I dug a little further into these warnings and found that, for the otk_install example, all the LNK4049 and LNK4217 warnings were caused by the OTK C++ xstring class. I attached the otk_install warnings to this post. Importing these 25 methods caused the 109 warnings in that file:
private: char const * __cdecl xstring::CastToCString(void)const
private: wchar_t const * __cdecl xstring::CastToCWString(void)const
public: __cdecl xstring::~xstring(void)
public: __cdecl xstring::operator char const *(void)const
public: __cdecl xstring::xstring(char const *)
public: __cdecl xstring::xstring(char const *,char const *)
public: __cdecl xstring::xstring(char const *,int)
public: __cdecl xstring::xstring(class xstring const &)
public: __cdecl xstring::xstring(void)
public: __cdecl xstring::xstring(wchar_t const *)
public: bool __cdecl xstring::IsEmpty(void)const
public: bool __cdecl xstring::Match(char const *)const
public: bool __cdecl xstring::Match(class xstring const &)const
public: bool __cdecl xstring::ToInt(int *)const
public: class xstring & __cdecl xstring::operator+=(char const *)
public: class xstring & __cdecl xstring::operator+=(char)
public: class xstring & __cdecl xstring::operator+=(class xstring const &)
public: class xstring & __cdecl xstring::operator=(char const *)
public: class xstring & __cdecl xstring::operator=(class xstring const &)
public: class xstring __cdecl xstring::Substring(int,int)const
public: class xstring __cdecl xstring::ToLower(void)const
public: int __cdecl xstring::GetLength(void)const
public: int __cdecl xstring::Pos(char const *)const
public: static class xstring __cdecl xstring::Printf(char const *,...)
public: struct __xstring_c __cdecl xstring::getxstring_c(void)const
There may be other OTK C++ classes that cause these problems. It would help if PTC eliminated these warnings from fundamental classes like xstring.
Well, if OTK C++ used std::string and std::wstring in place of xstring, that would eliminate the warnings I just mentioned!
|+|  M a r k  |+|
Apr 13, 2016 4:58 AM UTC
Just chiming in - I've seen the same warnings. I agree completely... I really don't like having to suppress warnings, especially because I personally like to use the "treat warnings as errors" option in Visual studio.
My temporary solution: I created a separate property sheet in visual studio to enable the OTK libraries, add the header directories, and remove the linker warnings.
Also, +1 for this:
FV_01
May 2, 2016 11:30 PM UTC
Hi all,
Back to the linker warnings.
Mark is correct - warnings had nothing to do with mixing C and C++ calls.
Microsoft has an explanation for LNK4049 :
Linker Tools Warning LNK4049
I had tried to follow Microsoft recommendations and this is what I'm guessing is happening.
I had dumped symbols out of otk_cpp.lib and sure thing for  xstring::xstring(...) there were a number of symbols with dllimport  and without dllimport, so when we are trying to link with otk_cpp.lib the linker is quite confused while parsing otk_cpp.lib. The answer the linker is trying to figure out if xstring::xstring defined locally in otk_cpp.lib why there was a number of dllimport(s) in the same library and this generates warnings.
Here is an example of dumpbin:
866 00000000 UNDEF  notype       External     | __imp_??0xstring@@QEAA@PEBD@Z (__declspec(dllimport) public: __cdecl xstring::xstring(char const *))
3372 00000000 UNDEF  notype       External     | __imp_??0xstring@@QEAA@XZ (__declspec(dllimport) public: __cdecl xstring::xstring(void))
3373 00000000 UNDEF  notype       External     | __imp_??0xstring@@QEAA@AEBV0@@Z (__declspec(dllimport) public: __cdecl xstring::xstring(class xstring const &))
3375 00000000 UNDEF  notype       External     | __imp_??0xstring@@QEAA@PEBD@Z (__declspec(dllimport) public: __cdecl xstring::xstring(char const *))
3376 00000000 UNDEF  notype       External     | __imp_??0xstring@@QEAA@PEB_W@Z (__declspec(dllimport) public: __cdecl xstring::xstring(wchar_t const *))
844 00000000 SECT146 notype ()    External    | ??0xstring@@QEAA@XZ (public: __cdecl xstring::xstring(void))
845 00000000 SECT130 notype ()    External    | ??0xstring@@QEAA@AEBV0@@Z (public: __cdecl xstring::xstring(class xstring const &))
846 00000000 SECT124 notype ()    External    | ??0xstring@@QEAA@$$QEAV0@@Z (public: __cdecl xstring::xstring(class xstring &&))
848 00000000 SECT12E notype ()    External    | ??0xstring@@QEAA@AEBU__xstring_c@@_N@Z (public: __cdecl xstring::xstring(struct __xstring_c const &,bool))
849 00000000 SECT138 notype ()    External    | ??0xstring@@QEAA@PEBD@Z (public: __cdecl xstring::xstring(char const *))
84A 00000000 SECT140 notype ()    External    | ??0xstring@@QEAA@PEB_W@Z (public: __cdecl xstring::xstring(wchar_t const *))
84B 00000000 SECT136 notype ()    External    | ??0xstring@@QEAA@PEBD0@Z (public: __cdecl xstring::xstring(char const *,char const *))
